Farmall H will do the job
Andy Motteberg
04-03-2007 21:12:48
You need a Farmall H, The H is easy on fuel, very easy to operate and steer. Not too much power and not to less power. Most H's have hydraulics, PTO, & Belt pulley too. The Farmall H tractors sound great and work will actually be fun with a Farmall H. The H is easy to operate and easy to service too (even though you would not need to service a H much!). The M's are nice too, but the H would also do the job. The H can be used with a large variety of implements and equipment, You can use a 3 pt or loader on a H, but I would recommend using a live pump if you wanted that. I would get the H if I were you.
Don L C
04-04-2007 20:59:51
 Re: Farmall H will do the job in reply to Andy Motteberg, 04-03-2007 21:12:48
Andy the H or M does not have 3 point hitch.....they can be added for $700 plus labor..... they are also under powered and too fast for snow blowers.....Great tractors, I oun both..... .
Andy Motteberg
04-14-2007 12:58:45
 Re: Farmall H will do the job in reply to Don L C, 04-04-2007 20:59:51
Don, new 3pt hitch for a H or M is $700, but used ones are usually only $200-$300.
