Buying Farmall M
Brett
05-01-1999 12:14:24
I'm thinking about buying a "49" M . I have some concerns.1 motor was overhauled to high dome pistons & possible cam work. The guy says its pushing 50 some horse - is this possible?2- how good are add on 3 point hitches-power & cost?3 Its got good rubber,set of duals,hydraulics &runs good.Is $1500 a good price? ( mid Michigan) Any info will be appreciated. thanx Brett
John H.
05-04-1999 19:48:03
 Re: Buying Farmall M in reply to Brett , 05-01-1999 12:14:24
Brett,
Great tractor to have. For a 3-pt hitch, check out Saginaw Valley Tractor. I bought one for my 400 (which had 50 HP from the factory) and it works great. Dual cylinder, well built, and a great RED color. Not cheap, but cheaper than the others available out there, and great quality.
cook
05-02-1999 06:15:48
The M is a very good tractor. Our's has ben in the family since it was new. It still works during harvest running an 8 inch auger and moving the small equipment around the rest of the year.
The Red
05-02-1999 06:32:49
 Re: Re: Buying Farmall M in reply to cook, 05-02-1999 06:15:48
My neighbor Ernie still uses an M and a Super M for the feed grinder, pulling the fertilizer wagon around and pulling grain hoppers in the fall. Up until last spring the Super was still being used with a JD 4 row planter.
The Red. YES. GREAT PRICE!
05-01-1999 13:58:30
That is a lot of nice M for that price, esp. if the engine is fairly fresh. You can goose an M up to 75 HP+ or so with some of the soop up kits around.
RED Blooded
05-01-1999 13:29:07
Brett,here in SC a good M would go for more than that,that is when people will sell them.Sometimes even the ones that dont look so good go for around 800.Id say 1500 is a good price.
steve from MO
05-01-1999 12:43:52
Brett,
The "50-some horsepower" is very possible since the 400 and 450 got up into this range with basically the same engine. Modifications to a plain M to get that much horsepower are not that big a deal - just install the later piston and sleeve set, turn up the governor, and readjust the carburetor.
Most people in central Iowa where I grew up pulled 4-14 plows with an M.
Steve
