carb troubles
bnelly544
04-13-2007 19:03:16
thanks for the input on my tire question.nowi'm haveing trouble with the carb.it starts and idles just fine but at anything more than a fast idle i have to have the choke on at least half way. i had the carb apart last summer and put a kit in it then and it seemed ok, now the problem is back. i've had the carb off and cleaned out the bowl and checked for water. do the electric solenoids that shut off the fuel when the key is off ever go bad? maybe it lets enough fuel in to idle but not for high rpm?
bnelly544
04-14-2007 13:44:50
 Re: carb troubles in reply to bnelly544, 04-13-2007 19:03:16
sorry.. it's a 544 farmall, i don't see any iceing on the carb. think i'll look for a plug to fill the hole where the fuel shutoff solenoid is and see what happens
IH2444
04-13-2007 21:10:15
Yep sounds like the fuel shutoff solenoid might be jammed or bad. some have an adjustment where you can crank em open.
Cory A.
04-13-2007 19:52:51
Is the carb iceing up anywhere?
old
04-13-2007 19:51:14
What tractor????? ????? With out that info its very hard to even guess as to how to fix/help you
