My Opinion
A. Bohemian
04-15-2007 11:36:11
One of the number one rules of working on older machinery is that if it ain't broke, don't fix it! Don't assume the carb needs adjustment and start tweaking things!
Ten to one you'll regret it if you do.
I don't know if I've ever been around an old tractor that didn't puff occasionally at idle. I don't know if they all did it new, but I suspect they did. I was told once that back in the day of relatively low compression all cars, tractors, etc., did this at idle, but I wasn't there, so I don't know.
If your tractor starts and runs reliably; if it pulls well under load; if it responds to the throttle well; if fuel consumption is normal and if the exhaust is clear; if all these standards are met, I would NOT mess with the carb just yet!
A. Bohemian
04-15-2007 11:44:52
 Oh, yeah. in reply to A. Bohemian, 04-15-2007 11:36:11
Jeff is giving you some good advice, and if you have discolored exhaust, etc., he gave you a good place to start.
But if I read his post correctly, he neglected to tell you how to check the oil
You are right about the two petcocks on the side. Open the lower one. Oil should come out. If it doesn't, close the bottom one, open the top one, and add oil until it dribbles out the top one.
And now you know how to check the oil on a whole bunch of different kinds of antique machines, including good ol' Model T!
