Where's that 3-D Holographic Manual When You Need
A. Bohemian
04-17-2007 11:34:58
Quote: "The book picture is kind of confusing as to where or what it looks like."
Agreed. And how!
From you're description, you've found it, though. That little "crease" is it.
With the timing light, the motor is running, and you are checking the running timing. The mark on the flywheel should only match up with the mark on the housing when the timing is set statically (motor not running).
Full advance MEASURED AT THE FLYWHEEL can be had from table 2 on page 49. Note that the numbers given are for the DISTRIBUTOR and must be doubled (as outlined in the heading to the chart) for the flywheel.
