Thanks.
A. Bohemian
04-18-2007 17:29:07
In our little town, I was unable to locate barbed fittings with flared fitting threads - just pipe threads.
Now I know where to look.
I have the 5/16 neoprene fuel hose: I keep plenty on hand.
El Toro
04-19-2007 05:25:27
 Re: Thanks. in reply to A. Bohemian, 04-18-2007 17:29:07
Those push-on barbed swivel nuts are easy to install and they won't leak. We used them at work for installing instrumentation on vehicles undergoing engineering tests. This included fuel lines for measuring fuel consumption, oil pressure and fuel pressure to name a few. This was called low pressure hose even though it was rated for 200psi. There's no hose clamps required on these fittings. For hydraulic pressure we used braided high pressure hose and
the high pressure fittings that could be installed with wrenches. Hal
Dave BN
04-18-2007 21:20:29
I use steel brake line. It's cheap and bends pretty easy, although it can be tricky getting around the air filter etc. I don't feel safe with rubber or plastic hose as this runs close to the engine and could get caught in brush etc depending on how hard you use the tractor. Steel line (which I paint red) looks more origional also. I use compression fittings which are readily available. Dave.
