Fuel Line Woes Resolved - Sort Of...
A. Bohemian
04-19-2007 12:01:03
Well, I found the flair-fit threaded barbed hose ends. There were totally unavailable in our little town, so I drove toward the nearest city. The first suburban Auto Zone I passed had them. The manager (a tall blonde with a nice smile) told me she always checks the bin once a week and re-orders any fittings she is sold out of.
So, the Super C has a new neoprene fuel line. I put teflon tape on the threads, being VERY carful the first few threads had no tape, so hopefully I won"t have to remove the fuel line to get teflon out of the screen in the carb inlet (if a Zenith carb has one) or needle valve/seat (if the Zenith has no screen). Then I tightened everything and checked. No leaks.
She started and ran fine, at all speeds. I never consider any repair on a tractor satisfactory until I know if it will pull well, and I don"t like using improvised expedients on gravity feed fuel systems; we"ll see how it runs when I do a little shredding or bedding (the hardest work I do with this tractor).
But I must say, now that I know the original line was steel, the neoprene one stamds out like a Yugo at a Ferrari auction. Looks like I"ll be teaching myself to flair-fit or pressure-fit brake lines...
GordoSD
04-19-2007 19:29:13
 Re: Fuel Line Woes Resolved - Sort Of... in reply to A. Bohemian, 04-19-2007 12:01:03
How tall? How blonde? How nice? Address and zip code of the store? My Advance counter person is 300 lb Wasp, needs shave, haircut, and LOT'S of deodorant. Oh yeah, SHE is brunette. I love their Cashews, but I don't let her bag them!
Gordo
City-Boy McCoy
04-19-2007 15:31:21
To heck with the correct fuel line for the tractor! Could you tell us more about that tall blonde with a nice smile??? (Just kidding.) HAW-HAW! mike
RustyFarmall
04-19-2007 12:37:27
The original steel fuel lines used a compression fitting. No flaring is necessary.
A. Bohemian
04-19-2007 13:25:42
 Re: Fuel Line Woes Resolved - Sort Of... in reply to RustyFarmall, 04-19-2007 12:37:27
Thank you, Rusty. That's exactly the kind of detail I need.
I want this tractor as original as possible, even down to little things like the type of fittings on the fuel lines.
Meanhile, the neoprene line will allow me to run a tank of gas through the tractor every now and then. You've got to run them to keep them running...
glennster
04-20-2007 06:53:12
 Re: Fuel Line Woes Resolved - Sort Of... in reply to A. Bohemian, 04-19-2007 13:25:42
oem tractor parts has the orig steel lines for 19.000 for your super c. i checked this website, they dont have steel lines, but have a flexible rubber line.
