farmall 400 diesel
xfarmer
04-19-2007 13:09:19
I have a farmall 400 diesel that I am parting out if anyone is interested in any parts call or e-mail phone# (724)785-9707 Thanks.
ncdiesel48
04-19-2007 18:39:25
 Re: farmall 400 diesel in reply to xfarmer, 04-19-2007 13:09:19
You guys only make comments like these because you know nothing about them. The heads cracked because the owners didn't shut them down properly. These are some of the coolest engines.
Jimmy King
04-21-2007 15:16:23
 Re: farmall 400 diesel in reply to ncdiesel48, 04-19-2007 18:39:25
With that long stroke, 1480 high idle, you can lug that engine down and almost count the RPM's.
The one I had I could pull a 7ft roam offset all day on 2 gals of fuel an hr. On a 9 ft haybine I could mow 80 acres on a tank.
georgeky
04-20-2007 06:29:49
I am realitivly new at these engines. What is the proper shut down procedures.
the Unforgiven
04-19-2007 21:36:23
Gee nc, I was only joking. I know what makes them crack, and the fact remains that a lot of them are cracked. I have run them for thirty years now, and I have been using one daily this spring, so I think "know nothing about them" is a bit rash.
the Unforgiven
04-20-2007 08:38:06
 Re: farmall 400 diesel in reply to the Unforgiven, 04-19-2007 21:36:23
You let it idle for a minute or so to cool a little if you have been pulling it, then switch back to gasoline and run for a couple minutes to cool more, then shut it off and throw the compression release back to the diesel position to allow the starting valves to cool on their seats. I would bet that a lot of the second owners, if not the original owners, just shut them off on Diesel and walked away, and never knew they had a problem until they pulled the head. I did until I actually read an owner's manual, never had any trouble until I gave the TD-6 to my sister, she wanted to freshen the engine up, and guess what, the head was cracked!
georgeky
04-20-2007 10:58:10
 Re: farmall 400 diesel in reply to the Unforgiven, 04-20-2007 08:38:06
I see, I have been going about it all wrong. Good thing I have not been working it yet. I have only had it running in the barnyard a little. I am still working out some bugs on it. I just bought it about 3 months ago, I hope it has a good head. It does run good. I am going to have to pull the head the gasket is bad and leaking oil from the front right corner of the head. I hope this is all that is wrong. It hadn't run in over 14 years when I got it. The guys I bought it from didn't know how to start it. It was their grandpa's. They tried to start it for three days. It took me and a buddy 20 minutes to get it running after we cleaned the tanks and filters. That is how long it took to bleed the system. It started right up. Thanks for the heads up.
A. Bohemian
04-19-2007 13:40:10
 Brave Man! in reply to xfarmer, 04-19-2007 13:09:19
I'll bet they're ringing the phone off the wall to find out if the head is good...
the Unforgiven
04-19-2007 13:48:20
 Re: Brave Man! in reply to A. Bohemian, 04-19-2007 13:40:10
Didn't those engines come with cracked heads?
xfarmer
04-20-2007 07:44:25
 Re: Brave Man! in reply to the Unforgiven, 04-19-2007 13:48:20
Any diesel that is shut down when the temp is hot may have a cracked head regaurdless of mgf.
