IH 340 Utility
Andy340
04-20-2007 06:23:42
Hello, I've got a 340 utility/backhoe and I'm looking for a place to get seals for the rear axle. I've seen some for the farmall 340 but I don't know if they would be the same due to the farmall having movable wheels. If anyone has a picure or exploded view of the hydraulic valves by the shifter, that would be great too. I only had one for the power steering and want to add more for remotes.
Andy340
04-21-2007 17:30:59
 Re: IH 340 Utility in reply to Andy340, 04-20-2007 06:23:42
Thanks, Great help! on the regulator(second from the left), I have a small fitting like the one going to the power steering but I'm not sure where it goes. Looks to be around 3/8. There is also a large tube going between the regulator and the tel-a-depth that is already hooked up. Thanks!
PaulW_NJ
04-20-2007 14:41:31
third party image
Andy
I have a 340U. I"m currently rebuilding my hydraulic valve manifold . . . here"s an image of it on the workbench with the valve covers removed. I can send you a blowup schematic if that would help.
I replaced one of my rear wheel seals . . . purchased a replacement at my NAPA dealer
PaulW_NJ
04-20-2007 14:49:35
 Re: IH 340 Utility in reply to PaulW_NJ, 04-20-2007 14:41:31
By the way, the two valves on the far right are for the remotes, the third is the Tel-a-Depth valve for the FastHitch, and the fourth is the pressure relief/safety relief valve.
