Please Back Away From the Toolkit
A. Bohemian
04-20-2007 11:55:16
Low idle: 425 RPM.
High idle: 1595 RPM. But read on:
Think about it. The tractor was running fine with the governor set up the way it was. Unless you changed the adjustments already, the odds are re-adjusting it won't make any difference.
ALL a governor does is help the engine run at a constant speed as load varies. Period. They rarely if ever cause rough running.
An exception: if the engine speeds up and slows down and can't seem to make up its mind what speed it wants to run at, the governor is often at fault. This is sometimes called hunting and can often be adjusted out.
Try this: with the engine off, grab the throttle rod. Move it through its range. It should be very free with little resistance.
Now start the engine. Grab the throttle rod again (watch those belts!) and try to move it. You should notice greatly increased resistance.
Increased resistance? Your governor is probably doing its job (unless it is hunting, as described above) and you should probably not mess with the adjustments until you are CERTAIN nothing else is wrong.
No resistance? The governor is NOT doing its job. It needs to be fixed before being adjusted.
Does the rod move back and forth of its own volition? The governor is hunting. Adjust it per the manual; if it STILL hunts, you may need a rebuild.
I don't bet; but if I did, I'd go dollars to donuts that unless you're experiencing hunting, your problem isn't the governor.
Bf8690
04-20-2007 12:16:54
 Re: Please Back Away From the Toolkit in reply to A. Bohemian, 04-20-2007 11:55:16
You're probably right that it morethan likely isn't the governor. However, the governor linkage directly controls the operation of the carb butterfly. When I got my M I didn't know if any of the adjustments were correct. After I rebuilt the motor and restored the tractor it wouldn't run right. I varified that everything was tight and that weren't any leaks. So I adjusted my governor, per the manual, and it purred like a kitten. It was however surging a little, which is what led me to the governor, as you explained. Then I did the carb modifications, because I pull mine, and it ran even better. The problem here is that he didn't really give enough info to help diagnose the issue. He asked how to do that so I told him. I figure he was asking because he had a surging/hunting issue with it, although he may not have.
