Maybe...kind of.
A. Bohemian
04-20-2007 20:37:16
There may be some kind of aftermarket conversion available. But if I am inferring properly from the IT manual, there never was a Farmall A with a water pump, not even Super A. They were all cooled by thermosyphon effect.
So no, you can't take one off a later model and stick it on; there were none!
This can be done with some early production Cs, apparently because Farmall had already decided to put a water pump on the Model C when it was introduced, but didn't get things ironed out in time for the beginning of the production run. So, Farmall made available a "Water Pump Attachment," and many of these tractors were retrofitted for water pumps, especially in the South and Southwest.
Some late-model Super As had a pressure-type radiator, which is a must with a water pump, and many of these radiators found their way onto earlier production As as replacements. Look for a vent pipe under the radiator cap lip.
Steven@AZ
04-21-2007 05:43:58
 Re: Maybe...kind of. in reply to A. Bohemian, 04-20-2007 20:37:16
My early '42 model H has a water pump and does not have the pressure-style radiator. Never had a problem with it, even running under full load in 100 degree weather it barely gets to the middle of "run" on the gauge...
Also, I have made do with some leaky radiators by simply not tightening the cap so they don't become pressurized - never had a problem with that, either. A person may run into trouble with that trick on these newer vehicles (especially the diesels) because they run such high temperatures for emissions and economy purposes...
gene bender
04-21-2007 03:02:56
In your experience what is your reason to think that a pressure radiator is a must. I have put several pumps on the 113 engine with no problems for large mowing units and was just wondering why there has been no problems with the stock radiator.
Red Dave
04-21-2007 10:26:03
 Re: Maybe...kind of. in reply to gene bender, 04-21-2007 03:02:56
I"ve done it too. No problems with the stock radiator here either. I guess I should have asked permission on here first.
A. Bohemian
04-21-2007 05:49:41
 Well, Then, I Was Wrong! in reply to gene bender, 04-21-2007 03:02:56
I thought that you had to have a full pressure relief setup to protect the seal on the water pump. I must have been misinformed.
Apparently, aftermarket conversions HAVE been done, so go to it.
