It May Not be an Exact Replica...
A. Bohemian
04-23-2007 15:53:47
...but if you're willing to spend the money, you may be able find a shop locally that will make embossed aluminium tags. They are still used for all sorts of things.
There is a shop in Austin, Texas that does it, and I have contacted them about having some made up for a radio-telegraph transmitter I am building from a 1941 design. I'd probably have about ten or fifteen each made up with common logos like "Plate" and "Tune" and try to sell them at radio swapfests to defray the cost. Maybe you could do the same at tractor swap meets.
Incidentally, the tag on the side of my Super C is simply illegible due to age (both of the tag and of my deteriorating eyes).
With the help of a flashlight and a magnifying glass I can make out a serial number stamped (not embossed) in the center and the words MADE IN US embossed (not stamped) in VERY small letters across the bottom.
It seems to have been painted black originally (the starter housing is black) but IIRC it had an unpainted spot in the middle where the serial number is.
I think our 1948 John Deere MT had a VERY similar if not identical tag on the starter. I've also seen them on other tractors, truck starters, washing machine motors and even the motor on my c. 1972 Sears paint sprayer!
I hope you can get someone to post pics of one of these in better shape than mine. Eventually, I AM going to paint my poor ol' Super C...
kfox
04-23-2007 20:10:28
 Re: It May Not be an Exact Replica... in reply to A. Bohemian, 04-23-2007 15:53:47
I used the tags from Clasic Chevy. They are the ones in the second post, and are identical to the origonals. I converted my generator to 12 volts so I used the 12 volt tag. I stamped the Delco part number from the H parts book, and added a /12 volts at the end of the number. I tried to post a photo, but YTBB is doing funny things now and wouldn't let me post a photo. ken
SuperA-Tx
04-23-2007 21:19:13
 Re: It May Not be an Exact Replica... in reply to kfox, 04-23-2007 20:10:28
Thanks Ken, Im going to order one tomorrow from there. Guess I'll find someone to stamp it or engrave it.
I did find a site (link below) that has the serial/part numbers listed. I guess they are correct.
Looks like a Super A should have # 1107093 on it.
Link
