10-20
bob th
05-04-2007 06:36:14
Could someone tell me if if the intake valve on a 10-20 for #1 cyl. is the one closest to the fan or the one to the rear of the engine.
Thank you
Mike Androvich
05-04-2007 14:01:43
 Re: 10-20 in reply to bob th, 05-04-2007 06:36:14
Cylinder No. 1 intake valve is the second valve from the front of the block towards the radiator. The first valve is an exhaust valve for cylinder #1. The cylinders are numbered 1 thru 4 starting from the radiator.
russ hamm
05-04-2007 12:52:42
Number one intake valve is closest one to the rear. You can look at the manifold and remember that there are only two intake ports and four exhaust ports. So the first valve to the front is exhaust, then intake/intake/exhaust/exhaust/ intake /intake/ exhaust.
El Toro
05-04-2007 06:39:32
No1 piston is at the front near the radiator. Hal
