farmall super c
brokenC
05-06-2007 09:57:52
had to take engine out of tractor put everything back together now the hydro. will not work can anyone help me on how to bleed this system. thanks
georgeky
05-06-2007 11:30:17
 Re: farmall super c in reply to brokenC, 05-06-2007 09:57:52
I am having phone troubles. The regular pnone is broke, and the youngest boy will not put the rechargable on the charger so it is dead.If you email me your number I will call in a bit.
brokenC
05-10-2007 18:58:40
 Re: farmall super c in reply to georgeky, 05-06-2007 11:30:17
Geo from KY you hit the nail on the head. We did what you said to do and it works perfect.Thanks for your info. Saved us some money and time Thanks again Joe
brokenC
05-06-2007 11:12:38
George could you please email me your phone number, I will call you asap thanks Joe
georgeky
05-06-2007 11:17:04
 Re: farmall super c in reply to brokenC, 05-06-2007 11:12:38
I sent the email to you.
georgeky
05-06-2007 11:13:32
As soon as you open your email.
brokenC
05-06-2007 11:16:36
 Re: farmall super c in reply to georgeky, 05-06-2007 11:13:32
thanks George
brokenC
05-06-2007 11:09:02
I have done all of that , It does not do anything after I cycle it.
Dave_Id
05-06-2007 10:50:12
As George says, but do this about a dozen times. Then remove the cap, and make sure the oil is up to level
georgeky
05-06-2007 10:35:51
Take the filler bung out and cycle the system. It is self bleeding.
brokenC
05-06-2007 10:54:17
 Re: farmall super c in reply to georgeky, 05-06-2007 10:35:51
When the mower was up I took out the drain plug it had pressure on it oil went everywhere. I put everything back together like it was now the mower will not move it worked fine before I had to work on motor.
georgeky
05-06-2007 11:09:45
 Re: farmall super c in reply to brokenC, 05-06-2007 10:54:17
Bare with it. It will come back to life. Just keep working your control levers back and forth.
