Yep.
A. Bohemian
05-08-2007 08:03:50
Quote: "Since you left the switch on most likely you burned the points and maybe even burned out the coil."
Absolutely. At least EXAMINE the points; I think you'll find them obviously degraded.
It is certainly to be hoped the switch was not left on at the SAME TIME the twelve volt battery was hooked up!
