gear oil
aaron nadolson
05-08-2007 12:51:22
What oil to use in my transmission and independent power take off unit?
1954 Farmall 300 Utility with T/A
The manual called for SAE 80 in trans/ rear end and 10w for independent power take off
georgeky
05-08-2007 12:57:58
 Re: gear oil in reply to aaron nadolson, 05-08-2007 12:51:22
Hy Tran in both. Or any equivelent. Ta don't like thick oil.
dhermesc
05-08-2007 13:45:18
 Re: gear oil in reply to georgeky, 05-08-2007 12:57:58
Agreed
The manuals came out saying 80W 90 (or so) but it was later learned that the TAs didn't operate very well with the thicker oil. Later tractors with similar transmissions specify hytran instead of the heavier gear lube.
You can use the cheaper Hytran equivelents in those earlier tractors, its only when you get into the newer tractors or hydrostats that I would worry about using Case-IH Hytran.
