Farmall H frame rails
Aaron B
05-09-2007 17:10:48
I am just wondering if I can remove one frame rail at a time from my H to clean/strip and repaint. Not sure if I will have to brace or reinforce anything, or if I may have to block up the engine/transmission. I appreciate your advice! Aaron
ordfoSD
05-09-2007 20:44:15
 Re: Farmall H frame rails in reply to Aaron B, 05-09-2007 17:10:48
After you get them off, blast them. Then polish them up with 80 grit flap wheel on a 4 1/2 offset grinder. If you are a perfectionist, weld up the oblong holes from prior loader application and bore/file them to original diameter.Then a coat of epoxy primer. It's no sand. Then 4 coats of primer surfacer. Block sand with 220. Then four more coats andblock sand with 320. Then paint. I gaurantee you they will look like a granite counter top.
Gordo
randy hall
05-09-2007 18:11:32
yes you can do one frame rail at a time, but put a jack under the clutch housing to relieve the twisting when one rail is off.
John in Ne.
05-09-2007 17:33:01
I've done it on several of them.Make sure nobody will try to move it.On one of them I did,I had to use a large punch to get all of the bolt holes to line up again.Be sure to paint that part of the engine while the rail is off.John.
