B vs BN
BRAINFADE
05-10-2007 07:52:33
Im having a senior moment here. What exactly is the difference between a Farmall B and BN. I used to know this stuff. Really , I did!
gene bender
05-11-2007 03:46:49
 Re: B vs BN in reply to BRAINFADE, 05-10-2007 07:52:33
The BN does not use the A diff housings as the ones for an A do not have the bosses for rear tooling and drive componets for planters,fert and other stuff using the axles for drivers.
Red Dave
05-11-2007 03:53:12
 Re: B vs BN in reply to gene bender, 05-11-2007 03:46:49
Good morning gene. It's amazing how many misconceptions there are about these little tractors, isn't it?
Athol Carr
05-10-2007 14:30:19
All B and BN were narrow front, initially single wheel, later duals. The A is the same tractor, the BN uses the A axle housing extension on the right and a matching one on the left. The B uses 4 inch longer housings on both sides. The front wheel support is different on the A to take the wide front axle whereas the B and BN use a different front steering box etc.
Red Dave
05-10-2007 07:55:13
8 inches
The rear wheels on a BN are 8 inches closer together on a BN than on a B. This is because the differential shafts on each side of the differential are 18 inches long on a BN vs 22 inches long on a B. 4 inches each side X 2 = 8 inches diffeerence.
Brainfade
05-10-2007 13:57:53
 Re: B vs BN in reply to Red Dave, 05-10-2007 07:55:13
Were all B & BN narrow front ends then? An A was then nearly the same except a wide front end with offset engine?
Thanks!
Red Dave
05-11-2007 03:50:43
 Re: B vs BN in reply to Brainfade, 05-10-2007 13:57:53
Yes, all B's & BN's were narrow front. They could be single or dual fronts, both were an option.
The A used the same engine, transmission, final drives and other things. Many identical parts on A's, B's, BN's.
