Farmall H
Bob Pernic
05-10-2007 15:37:37
Can anyone tell me the approximate weight of a Farmall H? Thanks - Bob
MarkNOhio
05-10-2007 16:36:42
 Re: Farmall H in reply to Bob Pernic, 05-10-2007 15:37:37
Mine weigh on a certified scales 3930#. This is with fenders, belly pump, and belt pully. NO wheel wheights.
Mike CA
05-10-2007 16:24:08
3700 lbs without weight. Not to be confused with an M that weighs 5500.
georgeky
05-10-2007 21:12:42
 Re: Farmall H in reply to Mike CA, 05-10-2007 16:24:08
Mike, my 1950 M weighs just a little over 4800 on certified scales with no weights on it. My 44 H weighs a little over 3900.
Mike CA
05-10-2007 22:40:10
 Re: Farmall H in reply to georgeky, 05-10-2007 21:12:42
Apparently I'm going to have to stop blurting out things I am told on this forum.
georgeky
05-10-2007 23:15:22
 Re: Farmall H in reply to Mike CA, 05-10-2007 22:40:10
They all vary according to what is on them. For example one with fenders, belt pulley, wide front, bigger tire size and so on will weigh a little more. The Supers are a little heavier as well. As for blurting stuff, I told a guy the other night that his M would hold over 20 gallons of rear end oil, knowing perfectly well they hold 13 gallons. I have ran them for well over 30 years.
rust collector
05-10-2007 16:03:10
Nebraska Tractor Test # 334 lists the weight as 5550 for the distillate model. This probably included ballast for max pull test. I would have guessed the naked shipping weight at about 4500 lb.
