Power steering unit--Behlen
Bob Mn.
05-06-1999 17:25:48
When I purchased my "M" years back a Behlen power steering unit came with it and was to large in overall size to mount under motor cover or outside up by steering wheel.It is farmall red and for heavy turning, What model used it and whats it's value.
Sam Redford
07-17-2002 21:56:34
 Re: Power steering unit--Behlen in reply to Bob Mn., 05-06-1999 17:25:48
Do you have a serviceable Behlen power steering unit for sale and how much do you want for it?
Thank you; Sam Redford
Ronnie
05-06-1999 18:35:37
They were used on 350 and 450 as factory option. But used on M's and many more as a after market power steering. I'm working on a 350 and could use a Behlen pump for it e-mail me.
john d.
05-06-1999 17:42:23
Don't know what the value might be, but someone out there would probably pay several $$ for it! Those things were used extensively on M-SuperM models, and some H-SuperH tractors as well as other brands. The unit had 3 main parts plus hoses and mounting brackets. A fairly small hydraulic pump was installed in front of the distributor for power, there was a reservoir tank that mounted in front of the gas tank, under the hood, on the right side. The part you describe is the actuator, and does the work. It was installed by cutting the steering shaft a few inches in front of the light bracket and then coupling the shaft ends to the actuator unit.
These were very dependable units as long as you keep oil in them. I've got one on a Super M that's served well for over 35 years.
Sam
05-06-1999 19:13:40
 Re: Re: Power steering unit--Behlen in reply to john d., 05-06-1999 17:42:23
Give you $25 for it. The value would be $350 guessing. If it s all there and working.
tom
05-06-1999 18:03:34
they were used on farmall 400 and 450.
