Reference hot coil
Bill
05-06-1999 20:24:09
just wanted to thank John amd RKS for the info--did have coil wire on hot side of the started changed that and replaced coil and ran without problem hope that was all there was to it
(had just changed points and condenser last week so they should be good)]
Thanks again
RKS
05-07-1999 03:02:04
 Re: reference hot coil in reply to Bill, 05-06-1999 20:24:09
Good for you it's running. Unfortunately, you may have solved a long term problem with a short term new coil. It is very important that you review where the resistor is in relationship to the hot lead to the coil. This is not clear from your post. The resistor must be in series between the coil and positive battery voltage or pos alt output. It seems to be most convenient then to connect it to the "dead side switch." [[If your resistor is between the battery and the "hot side of the switch," it is wrong, but would work ok as long as the alt "BAT" terminal was connected directly to the pos terminal of the battery or anywhere between the battery and the resistor (but not between the resistor and switch)]] Both the battery pos voltage and the alt "BAT" terminal **must be** on the "opposite" side of the resistor from the coil, or the new coil may eventually fail. RKS
