This Just In!
A. Bohemian
05-15-2007 10:57:34
Quote: "When your tractor is not to be used for some time, it should be stored in a dry and protected place. Leaving your tractor outdoors, exposed to the elements, will result in materially shortening it's life."
That's hard to argue with, but this being the internet...
Look at it this way; if you had a shed available, would you still keep your otherwise carefully maintained tractor outside? Why not?
That's what I thought.
You can get one of those little carports for under a grand and add some kind of siding to it. It's not that big a deal and it's the right thing to do; and on some level almost everyone would acknowledge that.
chadd
05-15-2007 14:25:25
 Re: This Just In! in reply to A. Bohemian, 05-15-2007 10:57:34
Obviously, if you have a shed that wasn't being used for anything else, it would make sense to put it in it. My point was simply if they don't have a shed, it is a little pointless to just suggest that their problem would be solved by getting one. Obviously there is some reason they feel that they don't need or can't obtain a shed, and that is not our business to argue. We don't have a shed currently available, and probably won't get one in the next 2 years, and I maintain them exactly as mentioned in the owners manual and repair whatever mechanical problem arises. I won't lose sleep over them sitting outside.
