460 utility
460d
05-17-2007 19:48:06
what is the best place for a complete breakdown of of this unit. I want to restore the tractor but would like to get a ballpark of cost. for now anyway just need it to be running. I know the engine needs overhauled no bigdeal I NEED to know about the rear end and how hard is it to replace all the seals, bearings.
460d
05-17-2007 21:41:15
 Re: 460 utility in reply to 460d, 05-17-2007 19:48:06
sorry not enough info on first post 460 utility gas no ta I just want ot replace the seals I guess first tear down that I will be doing
Janicholson
05-17-2007 21:50:34
 Re: 460 utility in reply to 460d, 05-17-2007 21:41:15
Many of the most leak prone seals do not require a teardown to replace them. Some do, but manuals are the key. Also keep asking us, we have been there many times on many occasions (collectivly) JimN
K.B.-826
05-17-2007 20:05:50
You'll be looking at $10,000 easily if you're planning on removing every last nut and bolt. Engine overhaul can be a very big deal. Could run you close to $5000 if you go all out and rebuild the injection pump, replace injectors, and machine the block to accept the press fit sleeves to avoid the sleeve cracking issues these engines had. Are there any known problems with the rear end? The TA is the most common problem, but can be replaced for under $1000 if you do the work yourself. There's usually no need to tear into the transmission unless there's a failure. Go to your local Case-IH dealer, get a parts book, make a list of every part you think you need, then have them price it all out.
Janicholson
05-17-2007 20:02:55
Service manuals, repair manuals, and owners manuals. Both from CaseIH, and IT. The questions you raise are almost all addressed in those. We can help with diagnosis if given specifics. JimN
