Nat
Bob
05-20-2007 20:01:13
You posted:
"For use WITHOUT an external resistor" = Has a ballast resistor built into the coil, so no separate ballast resistor is necessary. The coil itself is still 6V."
WRONG... in almost all cases, a "true" 12-Volt coil is simply wound with more wire in the primary winding. There is NO resistor built into the coil, other than the primary winding itself.
