Order Farmall Cub Parts Online
Cub wheel spacing diagram
booch
05-21-2007 10:05:26
Hi,
I need to get a Cub wheel spacing out to 60 inches (5 feet on center for back wheels). Does anyone have a copy of the rear wheel spacing diagram? We couldn't find one in our operators manual. Even a discription of what combo of wheel dish and bolt mount to get 60" would be helpful.
Thanks for any info.
Paul
Pete in Cal
05-21-2007 13:57:16
 Re: Cub wheel spacing diagram in reply to booch, 05-21-2007 10:05:26
booch, According to the Operators Manual for the Cub the maximum spacing is 56 5/8 inches. To do that the diagram specifies for the rear wheels turning the "wheel disc" out, mounting the wheel with "lug" outside of the "wheel disc" and the "tire" out. That gives max spacing. For the front raise the front of the tractor and loosen the bolts holding the axle extension clamps, pull the extension clamp pins, remove the bolts from the tie rod clamps. Pull the axles out an equal distance on both sides, and move the tie rods to correspond. Replace axle pins and bolts on tie rods and axle clamps. Set toe-in to 1/8 to 1/4 inches. Good luck.
booch
05-21-2007 18:26:08
 Re: Cub wheel spacing diagram in reply to Pete in Cal, 05-21-2007 13:57:16
Hi Pete,
Thanks very much. Hopefully its all not too rusted up!
Best,
Paul
