whats it worth
arthur ward
06-02-2007 19:10:08
farmall a, don't know the year. it has a rebuilt motor recently and decent paint. also has a loader. any idea on worth?
Steven@AZ
06-02-2007 19:49:17
 Re: whats it worth in reply to arthur ward, 06-02-2007 19:10:08
Anywhere from $500 to $3500. Vague description without pictures = vague answer.
My Dad taught me an important lesson early in life: "it's only worth what the next guy will pay for it."
Janicholson
06-02-2007 19:34:51
We really do not have enough info to estimate. Between 800 If bad tires, and 2000 with nice tires, and if the loader has a good hydraulic system to lift it. A Farmalls had no hydraulic system, so how that was made possible is important. If a super A, or a C/super C engine was used, they have provision for hydraulics. JimN
arthur ward
06-02-2007 19:41:41
 Re: whats it worth in reply to Janicholson, 06-02-2007 19:34:51
hi
it has good rubber all around. great shape actually. i believe it has a pump on the back for the loader. any idea from that? also, he said it is about 22 h.p. now. he wants $2000
Janicholson
06-02-2007 20:20:01
 Re: whats it worth in reply to arthur ward, 06-02-2007 19:41:41
With that info, if it runs for an hour while you mess with it, and it has no cracks in the front of the block, (it is frameless, and uses the engine for a stresses member) Modest loads only on the loader, 500 lbs, smooth hard ground, or sell the loader. then Buy it. JimN
arthur ward
06-02-2007 20:30:06
 Re: whats it worth in reply to Janicholson, 06-02-2007 20:20:01
ok, thanks for the input folks, i appreciate it.
Steven@AZ
06-02-2007 20:00:28
$2000 sounds fair if it runs excellent and has decent tin.
I believe they were closer to 18 horsepower unless the engine has all the hop-up tricks...
Personally, I would be concerned about the loader on it. I have seen several with cracked blocks or other stress-related damage without a loader on them. Inspect it really well, the block behind the carburetor is a common place for a crack.
CNKS
06-02-2007 19:49:01
That is a PTO driven pump, probably OK, but the PTO is not live. Meaning it will not turn and lift your loader with the clutch pedal pushed in.
