Farmall B governor lubrication
big fred
05-10-1999 06:54:09
What lubricates the governor on a Farmall A and B? The spring in mine RUSTED through, and the thrust bearing is on its last legs, but I see no provisions for lubrication. When I put it back together, should I just pack the thrust bearing, and needle bearings with grease, or is there some "right" way to take care of this problem?
Stan(VA).
05-11-1999 04:43:22
 Re: Farmall B governor lubrication in reply to big fred, 05-10-1999 06:54:09
I believe that lubrication was splash from the crank and cam gears up front. The rust seems to be common in tractors that have sat for years and had lots of chances for condensation to appear.
Stan(VA).
