F-30 sleeve seals
BT in NE
06-06-2007 19:20:32
How hard is it to get the o-ring seals for the sleeves? I have got two pistons out but am having trouble with the other two. I am thinking about building a pusher on a hydraulic jack to mate with the connecting rod and try to push everything out the top. I figure I can separate everything later. Is this not a good idea in your opinion? I think it would be a good idea to get to the bare block and clean the rust out but if I can't find seals I am going to have to be a little more careful. If anyone has a better idea please share it as I am trying to do this without destroying any parts. Thanks fou your help. BT
James Williams
06-06-2007 20:51:12
 Re: F-30 sleeve seals in reply to BT in NE, 06-06-2007 19:20:32
BT,I just got done breaking a f30 loose,Take the clutch housing and presure plate off.Facing into the flywheel there is 2 holes across each other about 1.5in in diamenter,cut 2 peices of pipe about 12in long that will extend out pass the flywheel.Use a long bar rotating the flywheel back and forth,this will put direct pressure on the crank
jimmy
steelfronts
06-06-2007 20:17:16
You have the right idea . Gordon Rice on Clarion Penn has the seals
