Buying an H
LinemanFarmer
06-10-2007 13:45:15
I looked at an H today to possibly purchase. Its a 1945, it runs and drives, all orginal tires, tubes need replaced in the fronts, the backs hold air and have about 1/3 to 1/2 tread left. Has the generator and works. It runs pretty smooth, I didn't get to see it start cold, but it started ok hot it flooded a bit. The brakes do not hold very well but will stop you. The shifing in the transmission is really loose. It all feels good and goes in with out problem but its kinda sloppy. Just by looking at the tractor it has been taken cared of. Thats why I don't know what to thing of the shiffting. The grill has some dents but I think I can fix them. And of course there was unmeasurable greese on the tractor everywhere but I coudn't see that it has major leaks. The guy wants $700 for it. What do you guys think?
Thanks Derek
LinemanFarmer
06-10-2007 19:23:54
 Re: Buying an H in reply to LinemanFarmer, 06-10-2007 13:45:15
Thanks Fellas for the advice, I belive I will buy it.
Derek
Curt from MN
06-10-2007 18:46:03
If I had the $ would buy it. Chances are the sloppiness in the shifting is the end of the shift lever is worn. Especially likely if it likes to get jammed in 2 gears. Machine shop can rebuild it for fairly cheap. Should look like a T (my old one looked like a bayonet, sure does feel different with the right shape)
Aaron B
06-10-2007 15:53:19
I recently bought a 1945 H. All 4 tires needed replacing, but held air. Sheet metal is quite nice, although it is missing the fenders. I gave $775 for mine, and spent another $700 on new rubber, so my suggestion is to buy it. You'll have a hard time finding another for that kind of money that runs and drives well.
Steven@AZ
06-10-2007 15:13:03
see here for more advice
Frumpadump
06-10-2007 14:30:46
Really good price for a running H.
KRUSS1
06-10-2007 14:17:18
I think that is a good an H as you are likely to find at that price. If it is reasonably close to home and you want one, then buy it.
