Steering on IH 184 LoBoy
Bruce
05-16-1999 05:59:02
I did some repairs on this tractor for my aunt, and took it for a test drive. Steering to the left, the turning radius is fine, but steering to the right produces a very wide turning radius. Is this normal for this tractor? A quick look under the tractor did not reveal anything obvious. Can you help? Thanks for any and all help.
Jim
05-17-1999 07:09:21
 Re: Steering on IH 184 LoBoy in reply to Bruce, 05-16-1999 05:59:02
The 184 we have is the same.
Mike
02-01-2000 09:20:55
 Re: Re: Steering on IH 184 LoBoy in reply to Jim, 05-17-1999 07:09:21
I have both a 184&154 and have a few suggestions. Most likly you hit something and bent the drag link rod (longest one).Check your spindles when you turn full left/right you should be hitting the stops that are cast into the axle,if not then you have many places you can make adjustments.Also make sure the drag rod is not hitting the clutch cover(it`s close)you may have to relocate the steering arm on the str. box spline to get it right. Good luck,Mike
