H Hard Starting
Barnaby
05-26-1999 05:15:23
I have a 1945 H (with magneto) thats hard to start. Carbuerator has been rebuilt. New spark plugs/wires. Compression good in all four cylinders. Starter is spinning the engine rapidly. Governor responds well to varying loads. Timing is fairly close to designated notch (trips slightly after first notch). Runs well once started.
What else can I do? My next thought is to take the whole magneto assembly in for the once over. Could it be the impulse coupling?
Help!!!!!
mj delaney
05-27-1999 08:27:03
 Re: H Hard Starting in reply to Barnaby, 05-26-1999 05:15:23
These tractors were hard to start 20 years ago too! I think the magnets in the mag get weak as others have suggested.
I bet the tractors are next to impossible to start in the winter especially with heavy oil. It probably explains why people shift to 12 volt systems. I'm too much of a purist for that.
With ours,twenty years ago(mag unit) we used to flip it over with the crank two or three times switch off and the choke on. Then we would turn it over by the starter with the throttle closed pretty well down switch on and choke off. As I remember old "H" would eventually fire.
I now have a 50 "H" with coil ignition. Sometimes if it's sitting around long enough it's fussy to start. I like to think I keep it in tune too! My "H" is different than the mag "H" as I have to give it a lot more gas to start; and without flooding and that can be hard to do. I really had to have my starter and wiring in shape to get enough power. Once it's warmed up you just touch the starter button and she's away.
So, to conclude, they can be fussy to start. Check out your mag and your wiring. Stay tuned to this web page, and look for tricks.
The Red
05-26-1999 07:36:34
Barnaby, It appears you have eliminated all the other variables. I would have the mag worked on.
