Governor adjustment on Super A ???
bronco
06-01-1999 20:09:25
After replacing all the ignition components and adjusting the carb , I can't get the engine to slow down to a satisfactory idle {slow } speed. I think it's in the governor unit somewhere! Any suggestions how to approach the problem???
Curt Cooke
06-02-1999 05:39:09
 Re: Governor adjustment on Super A ??? in reply to bronco, 06-01-1999 20:09:25
The most common problem in this regard is worn out linkage and related parts. First adjust the throttle linkage between the carb and governor shaft to spec. If the problem persists it's because of worn linkage or the anti-surge spring being adjusted too far in. Back the surge screw out enough to be sure that it's not holding your idle up. The screw is located on the bottom of the governor housing under an acorn nut. If the problem still persists you'll have to compensate for wear by shortening the rod between the carb and the governor, usually by the adjustable turnbuckle on the rod.
Stan(VA)
06-02-1999 06:34:15
 Re: Re: Governor adjustment on Super A ??? in reply to Curt Cooke, 06-02-1999 05:39:09
Also make sure that the low speed adjustment screw on the carb throttle linkage isn't in too far, that will also keep it idling too high.
Stan(VA).
