SM clutch Timing gear questions
BDM
06-12-1999 17:59:03
Ok, im replacing the clutch in my 53 SM, I will be using this for pulling. Any suggestions on who to get a new Clutch/Pressure Plate and Throwout bearing from? I would like to get a heavy duty one if there is such a thing for tractors{you know, higher pressure plate ect}. Also I plan on installing a live Hydraulic Pump in the future, I have been told to make sure I have the hardend gear set up front, I was told the SM should have this but my source wasn't absolutly sure, though he did say the 400-450 series uses this set to prevent gear shear/wear. Any insite from those in the know? Thanks...
Brian
