Super A draw bar ---
bronco
06-12-1999 22:08:10
The SA has like stud bolts that hold the draw bar bracket to the housing. The Cub uses bolts. What are these studs called, their size and thread? Are they available? Are they removable? Seems like you would ruin the threads trying to get them out, which I need to do!
Daniel
06-13-1999 10:52:10
 Re: Super A draw bar --- in reply to bronco, 06-12-1999 22:08:10
The studs and nuts ARE still available from Case/IH-- also, you should be able to get the studs from a bolt supplier, not sure about the nuts. If you want them out, soak them good with penatrating oil, you can get to the back on part of them ,too. Then use two nuts on the stud you want out. Tighten them together and then turn the inside one to back them out. Good luck.
