Order Farmall Cub Parts Online
Hot start 49 cub
Bill Conklin
06-13-1999 05:07:08
49 cub loses power stalls and doesn't want to resart when hot. It's not overheating and starts cold fine.I checked mag in 250 oven for 1/2 hour and it still sparks. Compression 60-90-70-100 what's normal compression 110? I'm replacing rings and valves now any other suggestions on this problem? It gets plenty of gas so it's not a vent or anything like that Thanks for any help. Bill Conklin
Raymond(MO 53)
06-14-1999 14:51:00
 Re: hot start 49 cub in reply to Bill Conklin, 06-13-1999 05:07:08
The normal compression on the Cub is 110. So if you are arround the 60,70,90 range you do have some compression problems, but doubt they are causing the shutdown and hard restart.
C. Amick
06-14-1999 09:38:31
If all else fails, I would try putting a coil on it temparily bypassing the mag. How old is the condenser?
