Messy floor, M culprit
Bob seND
06-15-1999 20:39:50
I've constantly got oil on my shop floor. My worst leak is oil dripping out of the axle casting
where the left rear axle comes out. Is this from
being overfilled by the previous owner or is there
a seal that needs replacing? I've had the M for a year and I've been waiting all this time for the
level to decrease until it doesn't leak any more.
What is the likely problem and solution? Thanks.
Bob
'51 "M" Farmall
RED Blooded
06-16-1999 13:34:32
 Re: Messy floor, M culprit in reply to Bob seND, 06-15-1999 20:39:50
I agree that the seal probobly needs to be replaced,But you can probably shoot some grease in the fitting on the cap and itll stop temporarly.Done that a couple of times and it seem to work until I got time to change the seal.
Ronnie
06-16-1999 05:57:49
You need to replace the axle oil seal. Remove the wheel, then the four bolts and cap on end of the casting, you have your seal in the cap.
Jim
06-16-1999 07:00:11
 Re: Re: Messy floor, M culprit in reply to Ronnie, 06-16-1999 05:57:49
Be ready to replace the axle brg.
