Hydraulic fluid in the engine !
bronco
06-15-1999 20:42:31
Hydraulic fluid is leaking ino the engine crankcase, evidently from the pump on my Super A. How does this happen? Do I need to rebuild the touch control unit too or only the pump?
EPE
08-05-2004 11:57:30
 Re: Hydraulic fluid in the engine ! in reply to bronco , 06-15-1999 20:42:31
NOW I KNOW! MY SUPER A HAS BEEN LEAKING FLUID AND I COULD NOT FIGURE OUT WHERE IT WAS GOING UNTIL I DISCOVERED THE ENGINE OIL LEVEL IS WAY UP. AND SUDDENLY I HAVE OIL LEAKS ALL OVER.I THOUGHT THIS WAS HAPPENING SO CAME HERE TO FIND OUT.G-PA BOUGHT IT NEW,IT SAT 13 YEARS AFTER HE PASSED AWAY. I GOT IT 2 YEARS AGO.
Mac
06-17-1999 16:12:47
I rebuilt my pump last year. A small o-ring on the pump shaft gives out and allows hyd. fluid into the engine. Mine went all at once and in a matter of a few minutes my hyd. fluid was all in the engine. My hyd. quit working and she began smoking out the stack like a steam engine. If you do it yourself be sure to mark the gears so they mesh the same when it goes back together. I didn't and now mine is noisy.
Mey
06-15-1999 21:32:01
Bronco, I'de rebuild the pump only, that is unless the touch control unit is not working properly. Mey
