Super A tire size???
bronco
06-17-1999 19:38:18
what is the correct rear tire size for the SA? I hear 9.5/24 and I hear 11.2/24 ?
Harold H
06-20-1999 19:10:00
 Re: Super A tire size??? in reply to bronco, 06-17-1999 19:38:18
Bronco,
The standard size tires from the factory on the Super A were 9 x 24 rear and 5.00 x 15 front. Optional were 10 x 24 rear, 11 x 24 rear, 4.00 x 15 front and 6.00 x 16 front. Hope this helps.
Harold H
Harold H
06-20-1999 19:19:37
 Re: Re: Super A tire size??? in reply to Harold H, 06-20-1999 19:10:00
Translate the old tire sizes to modern sizes as follows:
4.00 x 15 is still 4.00 x 15
5.00 x 15 is still 5.00 x 15
6.00 x 16 is still 6.00 x 16
9 x 24 is now 9.5 x 24
10 x 24 is now 11.2 x 24
11 x 24 is now 12.4 x 24
Any of these will be "factory correct" for your Farmall Super A depending on rim width.
Harold H
Stan(VA).
06-18-1999 11:15:44
What size rims do you have? You usually match to the rim size if you want it to look right. 8" rims get 9.5" tires, 9 or 10" rims get the 11.2" tires. That said, I agree with the last post, 11.2's do look less anemic. I've fit them on 8" rims before, they just curl in a bit at the rim.
Stan(VA).
Merlin
06-17-1999 20:17:55
9.5/24
