Order Farmall Cub Parts Online
FCUB valve guides
Bill Conklin
06-21-1999 15:42:55
I got the valve set for my 49 cub the other day and it came with guides.I wasn't planning on changing them but now that I've got them.Anyway the book says press them out, no can do the engine is still in the tractor and thats where I'd like it to stay. If I drive them down they'll hit the lifters before they come out.I did try a piece of 5/16 threaded rod and a socket figuring it would work as a puller and they would come out the top.Then I could just tap the new ones in but they're in pretty tight and I don't want break anything.Any suggestions from he experts? Maybe I should just let sleeping dogs lie. I've never broken anything I haven't touched:) So what do you think?
Walter
06-22-1999 08:19:55
 Re: FCUB valve guides in reply to Bill Conklin, 06-21-1999 15:42:55
Bill, I htink you should post this on the cub board at www.atis.com ..follow the links to the bulletin board there are a lot of knowlegeable people that post there I'm sure they can help.
Good Luck...Walter
Phil Auten
06-23-1999 05:48:10
 Re: Re: FCUB valve guides in reply to Walter, 06-22-1999 08:19:55
Bill,
That should be www.atis.net
www.atis.com is nowhere near the CUB board. Common mistake, I made it myself before I went back and read real careful.
Phil
Bill Conklin
06-23-1999 07:46:15
 Re: Re: Re: FCUB valve guides in reply to Phil Auten, 06-23-1999 05:48:10
Thanks everyone.
