Can't start 45 farmall
Bob Novick
06-23-1999 07:43:55
Can someone help this novice out. I rebuilt the
carb on this W-4 1945 classic and I am not getting
fuel out of the carb. I checked the fuel bowl and
there is fuel in it,but trying to start it I dont
see fuel flowing into the carb. Did I do something wrong, float level maybe. Any idea's , of course
if I spray some gas in the carb it starts and runs
a couple seconds.
Tim
06-26-1999 05:57:04
 Re: Can't start 45 farmall in reply to Bob Novick, 06-23-1999 07:43:55
Bob, Have you checked the ventura tube? I had a similiar problem w/ my 49-h and found that the ventura was plugged. I was getting fuel in the bowl, but the fuel wasn't being picked up and sent back to the top of the carb. Hope you get it going! Tim
not a Farmall
06-24-1999 08:22:51
A W-4 is not a Farmall although many people call them that
The Red
06-23-1999 08:35:01
That carb ought to be similar to the H. Did you blow out the channel where the fuel screen goes in? It may be that the needle is sticking.
bob novick
06-23-1999 08:59:58
 Re: Re: Can't start 45 farmall in reply to The Red, 06-23-1999 08:35:01
i did check it but will look at it more closer.
The Red
06-23-1999 09:13:44
 Re: Re: Re: Can't start 45 farmall in reply to bob novick, 06-23-1999 08:59:58
With the needle closed, the back of the float should be horizontal. Are you definitely getting fuel through the gas line?
bob novick
06-23-1999 10:17:37
 Re: Re: Re: Re: Can't start 45 farmall in reply to The Red, 06-23-1999 09:13:44
gas is getting to the carb bowl,but maybe the float isnt set right. horizontal maybe not,when seperate the bowl from top part its oh maybe
half full
