Belly or Dist Drive Pump
BDM
06-29-1999 19:41:10
Any idea's on which style pump has more pressure? And more volume per PSI? I know the Distributor drive pump is live, but Im wondering which one has more pressure, if there not nearly equal.. Thx
Brian
CHUCK FROM COLORADO
06-30-1999 21:39:32
 Re: Belly or Dist Drive Pump in reply to BDM, 06-29-1999 19:41:10
I understand that the SM belly pump was rated at 400 to 800 psi, depending on version and modifications, while the distributor pump was rated about 1200 psi, 12 gpm at 1450 rpm. I'm gathering parts and info to install a dist. drive pump on my SM, that we bought new in '52. Would appreciate any help in this matter. Thanks.
Chuck in Colorado
06-30-1999 12:09:52
For SM, belly pump pressure varied (400-800psi), depending on upgrades/modifications. The distributor drive pump was rated about 1200psi, 12gpm @ 1450 rpm. I'm thinking about adding the dist. pump to my SM, and would welcome any help.
Fudd
06-30-1999 19:55:59
 Re: Re: Belly or Dist Drive Pump in reply to Chuck in Colorado, 06-30-1999 12:09:52
Hey Chuck, be carefull and get several opinions as I read somewhere if you add a Dist. pump you have to put in heavier timing gears.
BDM
06-30-1999 20:24:01
 Re: Re: Re: Belly or Dist Drive Pump in reply to Fudd, 06-30-1999 19:55:59
Thanks guys for the follow ups. That is what I was told to, but the Gent who told me was about %90 sure the SM already had the heavier gears, he said chk the part numbers against a 400 or 450 or SM-TA. I haven't got around to doing that yet.
Brian
Jim
06-30-1999 15:26:54
Some belly pumps can go up to over a 1000lbs in pressure.But the biggest plus on the dist.drive pump is the Hyds. are live.
