Steering shaft support !!!
bronco
07-01-1999 20:22:43
The SA has a console where the steering shaft support attaches and supports the steering mechanism. That console base rusts out and you have a wobbly steering wheel, how best to repair it? The A has a steering shaft support that bolts into the housing and is solid . I wonder if a fellow coud change the SA to an A type without to much trouble?
Jim Becker
07-03-1999 20:03:44
 Re: Steering shaft support !!! in reply to bronco, 07-01-1999 20:22:43
Probably not without a lot of trouble. For one thing, I don't think the Super A bell housing is drilled for the big bolt that holds the support. However, An A support, with a pipe that reaches clear to the bottom of the instrument panel, might make an excellent repair part to weld into the Super A panel and allow for some extra bracing at the bottom.
