Power Steering???? Help please.
Bob Bearsch
07-05-1999 14:54:49
I have an IH 464 with power steering. The problem is that the faster the ground speed the harder the steering. I have to almost stop in higher gears in order to make the turn in a timely manner. I have changed the Hydraulic fluid, but this did not seem to help. Any ideas would be much aprecciated. Thanks, Bob B.
steve
07-06-1999 12:46:53
 Re: Power Steering???? Help please. in reply to Bob Bearsch, 07-05-1999 14:54:49
Are your belts slipping at higher engine speeds? Have you called and discussed this with a hydraulic shop? You might have to put a gauge in line and see exactly what is happening
with the pressure. Are you using the correct hyd. fluid?
Most hyd. pumps put out less pressure at lower speeds, so your problem is indeed odd.
Steve
