Farmall H with added power
Brandon Cloud
07-17-1999 16:51:07
I have a Farmall H with serial # 209391 = 1945 model. However, the decals on the hood are not that commonly seen on a regular H. It states that is has "Added Power" with larger pistons and sleeves. I also have an extra large oil filter assembly witch requires a specail oil filter that International does not make. Any ideas as to what this is?
Paul Fox
07-18-1999 03:29:52
 Re: Farmall H with added power in reply to Brandon Cloud, 07-17-1999 16:51:07
I'm guessing here, but it MIGHT be that it has had an M&W (or similar outfit) oversize sleeve/piston kit put in it at some time. This was fairly common when rebuilding worn out Farmalls. The "Added Power" decal may have been part of such a kit.
ltf in nc
07-18-1999 11:03:30
 Re: Re: Farmall H with added power in reply to Paul Fox, 07-18-1999 03:29:52
I am of the opinion that your "guess" is a correct call. The decal came with an overhaul kit as I remember.
Rusted Brain
07-17-1999 20:43:29
Could it be a SUPER "H"?
