Farmall M vs. AC WD45
Bob
07-21-1999 14:02:50
Anybody have any comments regarding the comparison between a Farmall M and an AC WD45? This question was posted on the AC board and I was interested in hearing opinions from both sides.
Todd
07-22-1999 07:30:42
 Re: Farmall M vs. AC WD45 in reply to Bob, 07-21-1999 14:02:50
I have a '48 M on my 20 acres. I have installed an aftermarket 3-point hitch. I use the tractor for everything on my farm from cutting grass with a bush hog to pulling plows and discs, to plowing snow in the winter. Even with the narrow front, its hard to beat my old workhorse. It sits up high enough to see all around and has enough weight to grind its way through my fields.
Jason
07-22-1999 03:40:22
you can do a lot more with the wd 45 than you can an m allis chalmers has a full line of equipment(blades, posthole diggers, mounted sickle bar mowers,sub soilers,mounted cornplanters, mounted plows), I was plowing with my dad he had an m I had my wd i out plowed him with my traction boost.
Wayne
07-22-1999 04:14:34
 Re: Re: Farmall M vs. AC WD45 in reply to Jason, 07-22-1999 03:40:22
A wd was cheaper than the M. But as soon as more money was available the wd was traded for the good ol M. Many more M's were sold.
Ronnie
07-21-1999 21:00:59
I drove both and I don't like sitting on the WD with my toes pointing at the sky.
HR
07-21-1999 17:30:19
Bob: If you were a full time farmer back when these were newer, you may not like sitting on smaller wheels bouncing around more and lower to the dust and dirt that blows up from the equipment so an M would be better.. An M would have been a better choice with a mounted two row picker for the same ground clearance reasons. More weight and better traction from larger diamater wheels was a known fact. The M was built for full time "Row Crop" type farming in tall corn. There probably was more acres of corn that went under Farmall H & M's than any WD or WD45 and row crop farming is\was the reason.. Maybe not which is best for cutting a lawn now for a hobby person but rather why these were built back 50+ years ago should be the real test of which was better suited to do what was needed back then...and Farmalls out sold WD's.. Harvey
Wayne
07-21-1999 16:46:29
The wd 45 is a newer tractor so it has more goodies. A SMTA or 400 would be of the same era.
Kev in Iowa
07-21-1999 14:33:34
A more fair compairson would be a 400 not an M..
mj delaney@gov.pe.ca
07-22-1999 06:42:16
 Re: Re: Farmall M vs. AC WD45 in reply to Kev in Iowa, 07-21-1999 14:33:34
They were both pretty good tractors. I agree with the last writer who said an IH 400 comparison would be closer.
On implements, to be fair "M" had access to only pull type unless he was specially equipped with three point hitch. IH had their own line of machinery. WD-45 had snap coupler unless he was specially equipped with three point hitch. So, Allis had a special line of machinery.
So I think this is a red herring.
Most WD-45's I saw in Canada were wide front end standards. Most "M"'s I saw in Canada were high arch row crop. A lot of aspects affecting manouvreability and handling would be tied up in this.
I always thought the WD-45 gas had a snappy governor, so they did real well on highly regulated work like running a combine. They had a hand clutch which was ideal to run a roto baler as you had to stop to tie every bale. Great power too. I bet the later buda diesels were awesome. I wouldn't even compare one of those to an "M"gas.
Old "M" was hard to beat just the same. Pull type equipment has it's limitations just like no live power. But the basic tractor remained unchanged since 1939 whereas WD-45's appeared in the early 50's.
Ironically, both types of tractors began to be displaced by tractors like 35 Massey's and 504 IH's and D-15/17 Allis, around 1959-60 with high power to weight ratios. We all know what has evolved since then.
If I was a betting man I'd say it'd be a draw. I liked features of both the WD-45, and M.
By the way I currently run a small farm with an "H", and 135 MF diesel.
I like both of them too. Also have a restored Allis "B" as a collector.
