Belly pump drive seal
BDM
07-22-1999 23:17:33
Has anyone ever changed the seal for the belly pump drive at the bottom of the trans? I have an SMTA manual which does not show this. Sounds stupid but I cant see how that seal cover comes off? The end of the pump output shaft is larger than the seal, or so it seems, and it does not look like its pressed on? Any suggestions?
Brian
Farmall Gray
07-24-1999 12:35:22
 Re: Belly pump drive seal in reply to BDM, 07-22-1999 23:17:33
The drive lug for the pump is threaded into the
shaft. Lock the brakes to hold the tractor and unscrew it from the shaft.
BDM
07-24-1999 19:45:27
 Re: Re: Belly pump drive seal in reply to Farmall Gray, 07-24-1999 12:35:22
Thx, do you know if its a left handed thread?
Brian
Farmall Gray
07-25-1999 14:08:12
 Re: Re: Re: Belly pump drive seal in reply to BDM, 07-24-1999 19:45:27
I don't think so.
BDM
07-22-1999 23:18:42
Whoooops, I forgot to add, its a Super M..
Brian
