Differential Shaft Bearing??
bronco
07-25-1999 21:41:43
How do you get the bearing on the long axle side of the differential housing out on a Super A ??? The housing is down and the seal is removed, but I can't get the bearing to break loose. It's like you have to get behind it !
Rick K
07-26-1999 07:50:29
 Re: Differential Shaft Bearing?? in reply to bronco, 07-25-1999 21:41:43
I seem to recall that when I did the left side on mine this spring, I had to do some tapping on the differential shaft to get the bearing to come out. It would not come out by just pulling it out from the outside.
