Live Hydraulics on Farmall H
Bill
01-29-2002 20:12:58
Can antone tell me if the Super H or 300 live hydraulic pump will bolt right up to my H or will I need a front timing cover also. I've asked 50 people and got 50 different answers. Bill
Bruce (WA)
01-30-2002 07:15:21
 Re: Live Hydraulics on Farmall H in reply to Bill, 01-29-2002 20:12:58
the bolt pattern on the pump is not symetrical like the one on the coupling so the front plate and cover is different onthe supers.
Dan
01-30-2002 05:06:26
No, the pump will not fit. You must change the timing cover and plate. I just ran into this.
Dan
Steven@nd
01-29-2002 20:59:04
Well, I put a Super M pump on my M and had to change the timing cover. I would assume the H is the same, to be sure, check the casting numbers on an H and Super H timing cover - if they are different then most likely you will need to change it.
Steven
