Need help on an H
Andy in Ohio
01-30-2002 09:12:42
I recently took the head off my H and had 1 burnt valve and lapped in the rest. Problem is when I put the head on and checked the compression I got none on 1 none on #2 and 80 on #3 50 on#4. What in the world did I do wrong?! Torque at 75 lbs and new head gasket. My IT manual isnt real helpful on this. Thanks for any advice.
R.David
01-30-2002 16:49:52
 Re: Need help on an H in reply to Andy in Ohio, 01-30-2002 09:12:42
The first thing I would check is the valve clearance. If you didn't readjust the valves, they are likely out of adjustment. Make sure the valves are opening and closing. If all that's OK, I think you will have to take the head off again. And check for a blown gasket. If you still can't find the problem, you may have broken rings. I had one years ago that had low compression and when I got it apart, three of the four pistons had the ring end gaps lined up, not staggered. Sometimes you never know. My IT shop manual is very helpful, but it's an old one. Maybe the new ones aren't as good. Good luck.
Steven@nd
01-30-2002 10:09:53
A couple of possibilities:
First, are the valves set properly?? Turn the engine over a few times with the valve cover off and be sure that all the valves are closing completely when they should.
Second, since you mention that #1 and #2 are both zero that would point to a leak between the two cylinders. If the valves are set properly and you still get no compression you may have to remove the head again and check to be sure the head gasket is sealing between #1 and #2.
Did you use a CaseIH gasket or other? I've heard that gaskets other than CaseIH sometimes do not work very well.
Steven
valve lash?
01-30-2002 09:35:47
Did you reset the valve clearance after your torqued the head down?? If not you likely have several valves not shutting tight.
Andy in Ohio
01-30-2002 18:41:59
 Re: Re: Need help on an H in reply to valve lash?, 01-30-2002 09:35:47
Thanks for the advice fellers it was the valves! I adjusted them and she runs like a champ! "Thanks again Andy
