806D big, big hydraulic leak
Alan
02-01-2002 08:24:03
Have an 806 with a massive hydraulic leak, lost almost all the hytran out the back after attempting to climb a hill. Thought the clutch was shot then saw the stream of hytran all the way back home. What could be the cause?? What should I look for??? Just got the tractor, runs good, have no history on it, Standard/wheatland, no 3pt. Any information would be helpful.
Matthew
02-02-2002 10:51:29
 Re: 806D big, big hydraulic leak in reply to Alan, 02-01-2002 08:24:03
It could also be the O-rings on the banjo fittings. They bolt into the top of the valve spools. There are two O-rings on each banjo, one on the bolt and one under the banjo. Also there are 3 o-rings in-between the stack of valve spools. They could also be the cause of your leak. The best way is to take the seat out and clean the area then start up the tractor and see where the leak is coming from.
Bermuda Ken
02-01-2002 09:21:23
Where exactly is the oil leaking from?? Is it from the rear hyd outlets?? Can you be more specific???
Alan
02-01-2002 09:28:44
 Re: Re: 806D big, big hydraulic leak in reply to Bermuda Ken, 02-01-2002 09:21:23
It seems to be coming from the remotes
Bermuda Ken
02-01-2002 10:49:55
 Re: Re: Re: 806D big, big hydraulic leak in reply to Alan, 02-01-2002 09:28:44
You probably need the following to stop your leak:
1 of 238-5011 oring, 1 of 238-6118 oring, 1 of 238-5212 oring and 1 of 396582R1 latching piston.
Start by removing the remote valve control lever from the valve spool. (tipping the seat head helps, as does removing the rear tin cover behind the valves). Remove the rear hex cap on the valve (the pipe tube should stay WITH the valve). Remove the valve spool. Remove orings inside valve housing spool bore. Check for scoring, wear, ect. Replace orings and latching piston. Reassemble in reverse order.
HOPEFULLY this will stop the leak. IF NOT you may have a cracked or broken valve housing and or tubing.
